My GE front load washer wont agitate but turns afew times very slow then the water fills and it turns afew more time as if to start washing but doent and the water drains without washing and it wont go into a spin cycle after all that it pauses with alot of time still left on the timer. I cleaned the trap but that didnt do it, plz help me ?:confused:
Ge does not release tech info, so about the best I can do is to have you look inside the service panel and see if you can find some tech notes that will let you put it into a diagnostic mode.
washer will only spin in one direction.
Hi Maestro
If you will start a new thread and include your model number and a more detailed description of the problem someone may be able to help. I am no longer responding to posts on this Forum.
Originally Posted by: maestro1928 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) washer will only spin in one direction. Maestro, It's most likely going to be a problem in the motor control unit Part number: AP4421584
. Use the attached tech data sheet and review the error codes and perform the recommended tests. You'll have it diagnosed and repaired in no time.
