jbustle
#1 Posted : Thursday, March 12, 2009 2:13:53 PM(UTC)
jbustle
How hard is it to replace the lower heating element on my oven?
TechnicianBrian
#2 Posted : Friday, March 13, 2009 5:45:42 AM(UTC)
TechnicianBrian
Turn the power off to the range. Remove the two screws at the ends of the element that hold it to the cavity, then slowly pull it toward you until you see the connectors on the ends. Then remove the connectors and install on the new element. If the wires come loose, then you will need to remove the rear panel to put them back on.
Frigidaire electric oven model number PLEF489CCF (Oven Repair (including Ranges and Cooktops))
by Guest 7/25/2021 4:06:10 AM(UTC)
Frigidaire Electric Oven Preheat Slow (Oven Repair (including Ranges and Cooktops))
by viralin 11/27/2016 11:15:26 AM(UTC)
Frigidaire electric Oven not heating (Oven Repair (including Ranges and Cooktops))
by pomps74 12/19/2015 11:18:10 AM(UTC)
Frigidaire Electric Oven Inconsistent heating (Oven Repair (including Ranges and Cooktops))
by JBicky 1/5/2013 4:11:34 PM(UTC)
Frigidaire Electric Oven/Range Problem (Oven Repair (including Ranges and Cooktops))
by stevo7fgg 6/9/2012 6:04:16 AM(UTC)
frigidaire electric oven/broiler won't heat. (Oven Repair (including Ranges and Cooktops))
by cartee 3/22/2012 7:51:35 AM(UTC)
Frigidaire Electric Oven Won't Start (Oven Repair (including Ranges and Cooktops))
by ltbird 12/4/2011 12:51:33 PM(UTC)
Frigidaire Electric Oven Doesn't Heat (Oven Repair (including Ranges and Cooktops))
by sharzaz 2/7/2008 3:57:25 PM(UTC)
Frigidaire Electric Oven Rear burner light wont go off (Oven Repair (including Ranges and Cooktops))
by seagullgeneral 12/14/2007 2:39:52 PM(UTC)
