AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Dryer motor will not go on when switch is pressed
The drum was not turning when the dryer was turned on. It did turn manually however. I went ahead and replaced the belt, the idler/pulley assembly, and the 2 rubber roller supports. The dryer seemed to be back to normal and was running good. Now it has stopped working again. When you press the button will not go on - nothing happens. Is it possible for the motor to be "fried out"?
Thanks.....
This is a gas dryer. Check the door switch for continuity. Make sure the dryer has power. Those dryer motors are preet darn good. Tom ApplianceEducator.com
The switch works- I checked it. When you press the start button, it'll make like a moaning/buzzing sound - it's trying to kick on, but won't. This morning I disconnected the belt from the motor. When you press the switch, the shaft will not spin on the motor. It just makes a moaning/ buzzing sound. I can also smell a slight burning smell - that's why I assumed the motor is going bad.
For what you tell me now, I will agree with you. Tom
Dryer Repair
