cadillac62
#1 Posted : Wednesday, March 11, 2009 4:55:11 PM(UTC)
cadillac62
I have a Jenn-air svd48600w gas-electric range. The oven bake does not work. the broil does work. Most likely the bake element is bad but how do I know it is the element? I hear the relay kicking on and off, so I am wondering if it may be the relay board. Your thoughts? Thanks
woodchuckie
#2 Posted : Wednesday, March 11, 2009 6:16:21 PM(UTC)
woodchuckie
Often times when an element is bad you can see a burnt spot on it with a close inspection. It also will show continuity with an ohm meter if it's good.
