dirtydishes1970
#1 Posted : Wednesday, March 11, 2009 2:54:28 PM(UTC)
dirtydishes1970
Normal and cancel light blinking continuously. Seems like some wire might have gotten hot? What should I look for I am against calling a tech out... Please help
kim ache
#2 Posted : Friday, March 13, 2009 7:17:48 AM(UTC)
kim ache
I am having the same problem, my cancel light is blinking and nothing else will turn on, mine is a Kenmore, did you have any luck yet??
#3 Posted : Friday, March 13, 2009 8:57:57 AM(UTC)
dirtdishes1970
Model Search
Here is the tech sheet
https://www.servicematters.com/d...0Sheet%20-%208572216.pdf
Tech sheet includes how to interpret lights, run diagnostics and also how to test the keypad for a stuck key using a meter.
First thing to try is remove power to the unit for half an hour or so just to see if it will reset.
kim ache
Please start your own thread using "Post New Topic" in this forum.
Be sure to add a Model Number, your problem may be totally different.
kim ache
#4 Posted : Saturday, March 14, 2009 11:08:24 AM(UTC)
kim ache
I have turned the power off for the evening and it still does not work. Thanks
Normal Wash Light Blinking (Dishwasher Repair)
by kevlarnovack 12/3/2007 5:56:39 PM(UTC)
