diverguy
#1 Posted : 16 years ago
diverguy
i replaced the complete control module 3 yrs ago and everything worked fine, now timer and clock-set have failed. lights still light up and i get audible tone when pressing stop/cancel button but that's it. if there is anything i could do without changing the module again i would like to know.
this site has helped me alot in the past...thanks
Drags1998
#2 Posted : 16 years ago
Drags1998
CAREFULLY recheck the wiring, If its OK, The EOC has failed again.
diverguy
#3 Posted : 16 years ago
diverguy
tried powering down unit by throwing the breaker. did sequence for re-setting clock, now everthing working. i guess only time (no pun intended) will tell.
thanks for the quick response, you guys are the best...
