i replaced the complete control module 3 yrs ago and everything worked fine, now timer and clock-set have failed. lights still light up and i get audible tone when pressing stop/cancel button but that's it. if there is anything i could do without changing the module again i would like to know.
this site has helped me alot in the past...thanks
CAREFULLY recheck the wiring, If its OK, The EOC has failed again.
tried powering down unit by throwing the breaker. did sequence for re-setting clock, now everthing working. i guess only time (no pun intended) will tell.
thanks for the quick response, you guys are the best...
