Tip
#1 Posted : Monday, March 9, 2009 6:45:57 AM(UTC)
Tip
It is a couple of years old but the pump got in a bind and would not rotate after very little use. I have replaced the seals, #7 and 8 on the exploded view but now there is a leak where the motor shaft enters the pump. I do not know why. Also why does the dishwasher have a spring between the seat and seal that is not shown on the exploded parts list? Perhaps I can not correctly install the new parts
Tip Mixson
C 502/330-4196
getzmel
#2 Posted : Monday, March 9, 2009 12:23:55 PM(UTC)
getzmel
I have the same problem like yours...leaking but i could not separate the pump from the motor
Should I replace motor coupling while replacing leaking pump (Washer Repair)
by CathyMomof4 5/7/2009 11:42:00 AM(UTC)
Leaking Pump Seal (Dishwasher Repair)
by rbh 4/30/2008 4:42:17 AM(UTC)
