It is a couple of years old but the pump got in a bind and would not rotate after very little use. I have replaced the seals, #7 and 8 on the exploded view but now there is a leak where the motor shaft enters the pump. I do not know why. Also why does the dishwasher have a spring between the seat and seal that is not shown on the exploded parts list? Perhaps I can not correctly install the new parts
Tip Mixson C 502/330-4196
I have the same problem like yours...leaking but i could not separate the pump from the motor
