markus
#1 Posted : Wednesday, November 14, 2007 10:35:14 AM(UTC)
markus
Can I bypass thermal fuse somehow to confirm dryer operation?
#2 Posted : Wednesday, November 14, 2007 10:59:38 AM(UTC)
What exactly is wrong with your dryer?
The best thing you can do is to check the thermal fuse (#7 on the bulkhead part break down diagram) for continuity.
Replace it if it's open.
The thermal fuse
UserPostedImage
- The part number for the thermal fuse AP3132867
According to the manufacturer instructions, if the thermal fuse is open, the cycling thermostat has to be replaced too.
The cycling thermostat
UserPostedImage
- The part number for the cycling thermostat AP3131939
- Here are the break down diagrams for the Whirlpool dryer Model LEC8858EQ0
markus
#3 Posted : Wednesday, November 14, 2007 11:07:18 AM(UTC)
markus
The dryer will not turn on, I have power. Was informed it may be the fuse. I do not have meters at my disposal.
#4 Posted : Wednesday, November 14, 2007 11:14:55 AM(UTC)
You have to perform the troubleshooting according to the wiring diagram bu you can not do it without a simple meter.
