my amana model amv5164aaq s/n 10353395el won't heat. everything else works with no unusual noise.replaced magnetron,diode,and capacitor. still no heat. any ideas.
Originally Posted by: jlune423  my amana model amv5164aaq s/n 10353395el won't heat. everything else works with no unusual noise.replaced magnetron,diode,and capacitor. still no heat. any ideas. Jlune, At this point, you'll need to check the #7 relay on the control printed circuit for voltage into the relay and out to the transformer. Black and Red wires on the relay terminal are power in(120 VAC) Black and Yellow wires on the relay are power out(120 VAC) to the transformer. You also need to check the secondary door switch circuit( the neutral side of the circuit). the C terminal will have the pink and White wires and the NO terminal will have the double White wires, that switch should have a "closed" circuit, when the door is closed. Good Luck, :) :) :)
