jlune423
#1 Posted : Tuesday, June 28, 2011 9:22:36 PM(UTC)
jlune423
my amana model amv5164aaq s/n 10353395el won't heat. everything else works with no unusual noise.replaced magnetron,diode,and capacitor. still no heat. any ideas.
Joe / APP Team
#2 Posted : Wednesday, June 29, 2011 6:24:04 AM(UTC)
Joe / APP Team
Jlune,
At this point, you'll need to check the #7 relay on the control printed circuit for voltage into the relay and out to the transformer.
Black and Red wires on the relay terminal are power in(120 VAC)
Black and Yellow wires on the relay are power out(120 VAC) to the transformer.
You also need to check the secondary door switch circuit( the neutral side of the circuit). the C terminal will have the pink and White wires and the NO terminal will have the double White wires, that switch should have a "closed" circuit, when the door is closed.
Good Luck,
microwave won't heat (Microwave Repair)
by Suefink 2/13/2013 2:53:07 PM(UTC)
Microwave won't heat (Microwave Repair)
by gkronenberger 11/24/2012 5:02:07 AM(UTC)
brand new microwave won't heat sensor error (Microwave Repair)
by redcellocase 6/8/2012 7:47:31 PM(UTC)
by lilbart 1/17/2012 9:24:27 AM(UTC)
by frankish 12/8/2011 12:38:07 PM(UTC)
Whirlpool Microwave won't heat (Microwave Repair)
by Wendy Porter 12/2/2011 5:45:04 PM(UTC)
by vangoy 12/1/2011 5:03:01 PM(UTC)
GE Profile Microwave won't heat? (Microwave Repair)
by bill007 3/3/2011 4:47:45 PM(UTC)
by mtorrey 2/12/2011 11:41:56 AM(UTC)
Microwave Won't heat food and turntable doesn't rotate (Microwave Repair)
by PaulieMo 1/24/2011 10:38:46 AM(UTC)
Microwave won't heat/Loud buzzing (Microwave Repair)
by grami 8/11/2010 5:14:13 AM(UTC)
Kitchen Aid Microwave Won't Heat Food (Microwave Repair)
by lmcalpin 7/20/2010 9:16:35 AM(UTC)
Microwave Won't Heat (Microwave Repair)
by cfairban 1/18/2010 10:21:36 AM(UTC)
Microwave won't heat, over the range Mcrw. (Microwave Repair)
by mbradyla 1/15/2010 10:52:20 AM(UTC)
by Joeblas 1/12/2010 5:34:48 PM(UTC)
