Woodman69
#1 Posted : Sunday, March 8, 2009 4:31:39 PM(UTC)
Woodman69
My freezer was previously freezing up and getting the refig box hot.
I ordered a new defrost heater with thermostat (AP2071465-GE#WR51X443)
and a new defrost control timer (AP2061695-GE#WR9X489).
Afterinstalling the new defrost heaters I noticed the lower heater glows and gets extemely warm, thawing out items and melting the ice in the icemaker.
The plug in on the old unit was split/cut so that the leads would match up and make a firm connection, so I did the same. ?I scares me that the unit is now overheating so badly. Could the new unit be wrong or maybe have a defective thermostat maybe.
The origional part numbers on the GE owners manual were:
Defrost Timer WR09X0489
Defrost Thermostat WR50X0122
Def Heater-Top WR51X0344
Def Heater-Bottom WR51x0345
Ilove the great service I recieved.. Please give me some ideas.
#2 Posted : Monday, March 9, 2009 3:17:26 PM(UTC)
The part number for the defrost heater assembly AP2071465is correct. I would recommend to double check all electrical connections for possible miswiring or cross wiring.
