bobb64@verizon.net
#1 Posted : Sunday, March 8, 2009 11:06:32 AM(UTC)
bobb64@verizon.net
timer will not stop running.goes past stop and does extra rinse and spin. is the timer bad?
kayakcrzy
#2 Posted : Sunday, March 8, 2009 4:26:05 PM(UTC)
kayakcrzy
It definetly sounds like a timer problem. The part # is 3955765. Tom
Dryer timer replacement help (Dryer Repair)
by Guest 6/20/2024 8:14:36 AM(UTC)
Amana Electric dryer timer for model LEA50AL (Dryer Repair)
by Guest 5/20/2024 5:37:01 AM(UTC)
GE dryer timer issue (Dryer Repair)
by Guest 5/8/2024 11:47:16 AM(UTC)
Whirlpool ler5635lq0 timer issue (Dryer Repair)
by Rolandtd 3/26/2024 6:15:44 AM(UTC)
GE Dryer Timer and Housing (Dryer Repair)
by Guest 3/25/2024 7:47:59 AM(UTC)
Hotpoint timer stalls in middle of opperation (Dishwasher Repair)
by Fidofax 2/15/2024 8:50:49 AM(UTC)
Dryer won’t stop after timer ends (Dryer Repair)
by ittssarah 2/4/2024 9:04:33 PM(UTC)
Kenmore 592-89032 Dryer POWERS OFF mid-cycle on both timer and moisture settings (Dryer Repair)
by Guest 7/15/2023 6:11:04 AM(UTC)
Alternate timer control for older Maytag top load washer ModelLAT8210AAW (Washer Repair)
by Guest 7/7/2023 12:43:57 PM(UTC)
Is the timer bad? (Dryer Repair)
by FatnSlo 5/1/2023 1:35:57 PM(UTC)
Dryer Timer Humming (Dryer Repair)
by terzolino 4/6/2023 10:18:16 AM(UTC)
Dryer won't start after changing fuses and timer (Dryer Repair)
by Guest 1/17/2023 11:21:44 AM(UTC)
GE Profile Range Timer Button Not Working (Oven Repair (including Ranges and Cooktops))
by Bush444 11/23/2022 10:11:35 AM(UTC)
PAVT910AWW Maytag no spin (agitates instead), no refill, no rinse, timer stops. (Washer Repair)
by owkaye 7/27/2022 5:04:45 AM(UTC)
Older Maytag top load “timer” (Washer Repair)
by CP1 6/4/2022 3:58:19 PM(UTC)
