mike2
#1 Posted : Sunday, March 8, 2009 8:40:48 AM(UTC)
mike2
I have a Jenn-Air double wall oven that is less than 10 years old. The control pancel has been repaired at least twice in the past 5 years. The cancel buttons are not working on either the upper or lower oven although all other buttons are working fine. The contacts have been cleaned also. Advice?
#2 Posted : Sunday, March 8, 2009 9:24:02 AM(UTC)
Model WW30430P
Here is a service manual
http://www.servicematters.com/m...ibrary/docs/16010312.pdf
Check out page 3-11.
It shows that track 1 is common to both upper and lower cancel buttons.
Check the switches with an ohm meter.
Inspect the track in the ribbon cable may have a hairline crack across it, a magnifying glass comes in handy here.
Check that the cables receptacle pins look OK.
Double check that it is clean.
STANB
#3 Posted : Sunday, March 8, 2009 9:49:09 AM(UTC)
STANB
now on my jenn air double oven just the opposite is happening the cancel pads make noise but all others do not work including the clock
