AppliancePartsPros.com
Appliance Repair Help
Washer Repair
put in new timer and still not going through cycles
My maytag washer would fill and agitate but would not advance through the cycles unless we manually advanced the knob. I put a new timer in and it is doing the exact same thing....any ideas?
If you manually advance the timer and then it spins and works ok you likely have a wiring or electrical problem. Check all the wires to and from the timer, and clean the contacts with a good contact cleaner.
This type of problem is difficult to find, good luck.
Washer Repair
