Indianriver
#1 Posted : Sunday, June 26, 2011 3:58:40 PM(UTC)
Indianriver
My maytag washer would fill and agitate but would not advance through the cycles unless we manually advanced the knob. I put a new timer in and it is doing the exact same thing....any ideas?
sidfink43
#2 Posted : Tuesday, June 28, 2011 5:14:00 PM(UTC)
sidfink43
If you manually advance the timer and then it spins and works ok you likely have a wiring or electrical problem. Check all the wires to and from the timer, and clean the contacts with a good contact cleaner.
This type of problem is difficult to find, good luck.
