jsthomas75
#1 Posted : Saturday, March 7, 2009 10:58:49 AM(UTC)
jsthomas75
I have a whirlpool gas dryer that will heat up and run for about 10 minutes, then makes a 20 second rattle and the heat stops. There is no issue with the tumbling, just the heat. I have checked the thermal fuse and that was fine. I also tested the gas coils on an Ohm meter and they tested to spec based on the information on this website. Is there anything I should be looking at that would cause a rattle and lack of heat?
Thanks!
kayakcrzy
#2 Posted : Sunday, March 8, 2009 4:15:14 PM(UTC)
kayakcrzy
I would replace the coils on the gas valve. Tom ApplianceEducator.com
