I have a Monogram refrigerator model number ZISW42FMD serial number HF031001 that I need to replace the switch on the refrig side. The switch is for the llight inside that automatically turns on and off when you open and close the door. I was told the part number is AP3193221. I need to know how to remove the old broken switch and replace it with the new one I purchased from you.
Slide a small flat-blade screwdriver under the switch and push the locking tab (look at the new switch). Pull out the switch.
