TCAULFIELD
#1 Posted : Thursday, March 5, 2009 10:26:40 AM(UTC)
TCAULFIELD
I have a Monogram refrigerator model number ZISW42FMD serial number HF031001 that I need to replace the switch on the refrig side. The switch is for the llight inside that automatically turns on and off when you open and close the door. I was told the part number is AP3193221. I need to know how to remove the old broken switch and replace it with the new one I purchased from you.
#2 Posted : Friday, March 6, 2009 10:39:23 AM(UTC)
Slide a small flat-blade screwdriver under the switch and push the locking tab (look at the new switch). Pull out the switch.
Guest (4)
