dlszds
#1 Posted : Tuesday, March 3, 2009 7:21:33 AM(UTC)
dlszds
Is it a simple matter of unscrewing the old bottom element from the back wall of the oven, pulling it out and inserting the new element.....or does it require a service tech to replace the element?
TechnicianBrian
#2 Posted : Tuesday, March 3, 2009 4:02:27 PM(UTC)
TechnicianBrian
Just remove the screws and slowly pull the element out until you can get to the connectors. If one of the wires falls off, then you will need to remove the rear panel to get it put back together so pull gently.
Replacing oven element (Oven Repair (including Ranges and Cooktops))
by Susan1 10/26/2010 10:59:05 AM(UTC)
question on replacing oven element (Oven Repair (including Ranges and Cooktops))
by wolfsmane 10/2/2009 8:39:12 AM(UTC)
