AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Maytag Neptune Electric Dryer (MDE3000AYW )will not start
Maytag Neptune Electric Dryer Model #MDE3000AYW purchased in 1999.
Worked fine in the morning, but in the afternoon but it would not start.
1. It has power. 2. The door switch works. 3. I suspected the push-to-start switch, so I opened up the rear top panel and got my voltage tester out and I have 120V to the red wires on one side of the switch. 4. I disconnected the switch and put my continuity tester on each contact. I have continuity between the two contacts when I hold the button down, but no continuity when I release the button. 5. I reconnected the switch and jumpered the two red wires that connect to contact #1 to the yellow wire that connect to contact #2. Still won't start.
Is that normal behavior? Are there any other tests I can try? Could it be the Drive Motor?
THIS FORUM IS DEAD!!!!!!! |
Dryer Repair
