bwintrow@hotmail.com
#1 Posted : Sunday, March 1, 2009 10:38:06 AM(UTC)
The Burners work well but the oven is digital and Keeps shutting off while trying to cook. It starts beeping and flashing a display F 3 code. You have to hit cancel and then bake and set temp. Also it will start beeping when not in use.
#2 Posted : Monday, March 2, 2009 4:11:37 PM(UTC)
Most likely the problem is a bad oven sensor, but there is a small chance for the control board to be bad too. The model number you posted does not come up. Verify and repost it.
Kitchenaid oven keeps shutting OFF (Oven Repair (including Ranges and Cooktops))
by jbili 10/16/2014 3:37:51 PM(UTC)
Oven keeps shutting off (Oven Repair (including Ranges and Cooktops))
by jstarin 1/11/2009 9:05:03 AM(UTC)
