The Burners work well but the oven is digital and Keeps shutting off while trying to cook. It starts beeping and flashing a display F 3 code. You have to hit cancel and then bake and set temp. Also it will start beeping when not in use.
Most likely the problem is a bad oven sensor, but there is a small chance for the control board to be bad too. The model number you posted does not come up. Verify and repost it.
