Hello I'm trying too see what part I need for this washer...The water goes in the washer but it doesn't spin it only spins when its on the spin cycle
Originally Posted by: Princess65 Hello I'm trying too see what part I need for this washer...The water goes in the washer but it doesn't spin it only spins when its on the spin cycle Princess, If you mean the washer won't drain, Check for a kinked drain hose, check for a clogged drain pump or a clog in the tub to pump hose. You may need a drain pump, if the impeller fins are damaged, Part number: AP4027705
Good Luck, :) :) :)
