tombulak
#1 Posted : Wednesday, June 15, 2011 7:35:35 AM(UTC)
tombulak
"Fridge and freezer slowly increased temp for about a week till neither compartment cools at all, condenser motor fan runs, freezer compartment fan runs, damper door seems to work. Any idea on what part needs replacing? Thank you."
:confused:
Striper19943
#2 Posted : Wednesday, June 15, 2011 10:46:22 AM(UTC)
Striper19943
:confused:
Mine has the same problem. Have tested the T-Stat and the defrost timer and they both check out. Then replaced the start relay and the capacito and it still will not kool below 43 in the freezer or the fridge part. Thinking I might need to relook at the defrost timer to see if it might not be working after all. will let you know what I find and if it might help you.
fridge and freezer not working but compressor and fan at bottom run (Refrigerator & Freezer Repair)
by bigherb2 8/3/2014 6:40:32 AM(UTC)
Fridge and Freezer not working (Refrigerator & Freezer Repair)
by gsalazar 2/20/2012 8:45:15 PM(UTC)
Kenmore Elite Fridge And Freezer Not Working (Refrigerator & Freezer Repair)
by cgrass78 7/15/2010 1:33:31 PM(UTC)
