Jowell135
#1 Posted : Saturday, February 28, 2009 7:44:05 AM(UTC)
Jowell135
I own several small cabins that have unvented propane inserts. Guests continually have trouble using them because they have a rotary type dial, low under the firebox which must be in a certain position to light the pilot, then turned in the right direction to light the flame and on and on. Is there any cost effective ( cheap) way to convert them so I can just add a wall switch to turn them on and off. Thanks,
John
Hearthman
#2 Posted : Saturday, February 28, 2009 5:43:36 PM(UTC)
Hearthman
Groups: Expert
No, sorry but you would have to change out the entire burner. Those thermostatic controls are a pain. Everyone turns the knob the wrong way shutting off the pilot. Then it goes into lockout making you wait before you can relight the pilot.
Now to the larger issue: VF in "small cabins". Sounds like a recipe for trouble. Consider switching to vented appliances instead of lung vented. You should also install unlisted low level CO monitors on each cabin.
VF must be kept clean with logs in the proper position. Not a good choice for public cabins with people in & out whipping up dust or getting creative "adjusting" the log position. Gas direct vent is the way to go.
Hearthman
