Tim Baumann
#1 Posted : 17 years ago
Tim Baumann
:confused: Ok, we need help. The Fridge worked fine when we plugged it it. Ran a new water line to it. It seemed to be making ice right away.
The fridge light switch was broken so HE tried to fix it. Eventually it shorted out.
Day 2 the water from the ice maker line froze up and leaked down, sounded like water was dripping on hot coils.
Unplugged the darn thing.
Did something short out?
Plugged it back in, the freezer light now flickers. HELP!:eek:
Signed, "The Wife"
#2 Posted : 17 years ago
:) Hi Tim's wife
The first thing I would do is to see how the fridge works without the ice maker. Lift all the way up the arm on the right side of the ice maker. It should turn the ice maker off and then run the fridge for a few days under you personal supervision. If anything wrong, let me know.
The next step is to check the ice maker and the water valve, but lets do one thing at a time.
About flickering light, check the light bulb for loosen connection. If this is not the issue then replace the light switch. Unplug the fridge first.
- The part number for the light switch AP2067519
Good luck.
Tim Baumann
#3 Posted : 17 years ago
Tim Baumann
Thanks for replying.
Yes, we are running the fridge with the ice maker off. Should we have done that when we first plugged it in? Is that why the end of the hose froze on day 2? It had already made a cycle of ice, then where the water fills the ice tray froze and water started being diverted down the sides. How do you keep it from freezing? The freezer light didn't start flickering until after that happened.
The original problem was the fridge side lower door switch that makes the light go off when you close the door. Eventually, after working on it, that shorted out. Wondering if that might have shorted something else out? We have already ordered that switch.(#WR23X10143)
The ice dispenser worked great for years before we moved it here. Would love for it to work again.
Thanks!
The Wife :o
#4 Posted : 17 years ago
Most likely the problem is a bad water inlet valve which is not closing completely after the ice maker filled with water.
- The part number for the water valve AP3672839
Good luck.
Cafe fridge keeps warming up. Help! (Refrigerator & Freezer Repair)
by Guest 9 months ago
Help! Washing machine on repeat rinse cycle (Washer Repair)
by cali.poppy 12 months ago
HELP!!! Maytag Lat9604abe leaking from weeping holes in tub seal (Washer Repair)
by gocanada72 about a year ago
Help! Washer chirping noise (Washer Repair)
by Guest 2 years ago
Troubleshooting Help!! (Dishwasher Repair)
Kenmore Dryer, Help! (Dryer Repair)
by C DeBardeleben 2 years ago
Maytag Dryer MGD7230HW2 LP CONVERSION HELP!! (Dryer Repair)
by prodigey 2 years ago
KitchenAid Artisan unknown problem. Please help! (Blender Repair)
by fakupos 3 years ago
Mah2400aww Maytag Door Boot Door Diaphragm Discontinued, Help! (Washer Repair)
by DIY_Vee 3 years ago
Ice maker dispenser will not stop running - help! (Refrigerator & Freezer Repair)
by Guest 3 years ago
Maytag Bravos MCT HELP!!!!! (Washer Repair)
Help! Does motor need to be replaced or cleaned out? (Dishwasher Repair)
by connellh 4 years ago
Kenmore not cooling - Can't get a replacement fridge HELP! :) (Refrigerator & Freezer Repair)
by shorton 4 years ago
Help! GE Profile Electric Oven PT916SMSS (Oven Repair (including Ranges and Cooktops))
by Marsa 5 years ago
HELP! Need clip or nut for Foot on Frigidaire Gas Range (Oven Repair (including Ranges and Cooktops))
by RichardKY 5 years ago
