need to replace the relay kit attached on the compressor need help how to take off the part on the safer side without removing the compressor part # ap4009660 by whirpool
Rank:: Advanced Member
Insert a flat screwdriver between the relay and the compressor and pry the relay out. Be careful not to damage the compressor terminals.
