Not long after i brought this roper from lowes. within about 2 months after i purchased it, it doesnt dry as good for the 1st time. i would put in 70 mins full on or prefer setting to save energy. it wont completely dry until the 2nd or 3rd time. im anxious to get this fix, i cannot afford to wait 2 hrs to get that load done before i put another in and waste my disability money on electricity.. please help, what's wrong with it and what does it need and how to repair it?:confused:
Most common cause is a vent problem.
Vent Check Undo the dryer from the exhaust Run a load If the load dries correctly then you have a vent problem. Clean/check the vent system. Make sure the outside louvers open fully.
If you do not want lint in the house. Take a pair of pantyhose, put one leg into the other and attach this to the dryer exhaust. Leave enough room behind the dryer so it can blow out like a windsock. Run a load.
Both the above will allow you to check the air flow and temp. Also the above is NOT recommended for a gas dryer due to possible carbon monoxide problems. |
THIS FORUM IS DEAD!!!!!!! |
