mamaof3pinks
#1 Posted : Thursday, February 26, 2009 6:51:46 AM(UTC)
mamaof3pinks
Not long after i brought this roper from lowes. within about 2 months after i purchased it, it doesnt dry as good for the 1st time. i would put in 70 mins full on or prefer setting to save energy. it wont completely dry until the 2nd or 3rd time. im anxious to get this fix, i cannot afford to wait 2 hrs to get that load done before i put another in and waste my disability money on electricity.. please help, what's wrong with it and what does it need and how to repair it?:confused:
#2 Posted : Thursday, February 26, 2009 6:58:08 AM(UTC)
Most common cause is a vent problem.
Vent Check
Undo the dryer from the exhaust
Run a load
If the load dries correctly then you have a vent problem.
Clean/check the vent system. Make sure the outside louvers open fully.
If you do not want lint in the house.
Take a pair of pantyhose, put one leg into the other and attach this to the dryer exhaust.
Leave enough room behind the dryer so it can blow out like a windsock.
Run a load.
Both the above will allow you to check the air flow and temp.
Also the above is NOT recommended for a gas dryer due to possible carbon monoxide problems.
