VICKIE KRIZANEK
#1 Posted : Wednesday, February 25, 2009 3:55:34 PM(UTC)
VICKIE KRIZANEK
My Dryer Has Just Started Where It Doesn't Want To Heat. Sometimes When I First Turn It On It Will Work For A Few Min. Then Just Quits. Sometimes It Won't Heat Up At All. I've Checked The Vent And Even Vacuumed Out The Back Of The Dryer In Case Of Dust In The Dryer Itself. I Still Have The Same Problem. Sometimes I Can Put It On A Different Setting And Get A Little Heat Out Of That Also, But Not For Long Once Again. Please Try And Help Me Figure This Out, I Cannot Afford A Repair Man On Disability.
kayakcrzy
#2 Posted : Thursday, February 26, 2009 4:36:23 AM(UTC)
kayakcrzy
Vickie replace the coils on the gas valve. It sounds like the secondary coil is not working. It is an easy and cheap fix. Tom
VICKIE KRIZANEK
#3 Posted : Saturday, February 28, 2009 9:38:55 PM(UTC)
VICKIE KRIZANEK
thank you so much for your information. i will go out and get them tomarrow, as long as i can locate them, and replace them. i'll let you know if it works.;)
kayakcrzy
#4 Posted : Sunday, March 1, 2009 3:42:21 AM(UTC)
kayakcrzy
Good Luck Tom ApplianceEducator.com
