AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
dryer seems to dry for only a few min. if at all
My Dryer Has Just Started Where It Doesn't Want To Heat. Sometimes When I First Turn It On It Will Work For A Few Min. Then Just Quits. Sometimes It Won't Heat Up At All. I've Checked The Vent And Even Vacuumed Out The Back Of The Dryer In Case Of Dust In The Dryer Itself. I Still Have The Same Problem. Sometimes I Can Put It On A Different Setting And Get A Little Heat Out Of That Also, But Not For Long Once Again. Please Try And Help Me Figure This Out, I Cannot Afford A Repair Man On Disability.
Vickie replace the coils on the gas valve. It sounds like the secondary coil is not working. It is an easy and cheap fix. Tom
thank you so much for your information. i will go out and get them tomarrow, as long as i can locate them, and replace them. i'll let you know if it works.;)
Dryer Repair
