larry.blythe
#1 Posted : Saturday, June 11, 2011 9:50:16 PM(UTC)
larry.blythe
GE washer will agitate, but does not spin in any cycle . Where do I start?
sidfink43
#2 Posted : Monday, June 13, 2011 5:03:17 PM(UTC)
sidfink43
Your motor has an inverter, and the inverter flashes green light for error codes.
This site here will tell you how to check it. First to the reset thing, that might be all you need to do.
HydroWave GE Washer Repair Guide
larry.blythe
#3 Posted : Monday, June 20, 2011 11:44:57 AM(UTC)
larry.blythe
Your reply to my problem, was timley but unfortunatley the info you provided doe'st apply to my machine. The machine I have is a bare bones no frills model There is no light on the motor to test. model # is WCSR2090G3WW. When the timer reaches the spin mode, I hear a clunk=sound which of course is normal for transmission shift . But the motor does'nt energize. I think I may need instructions on how to disassemble the wash=basket /Thanks
sidfink43
#4 Posted : Monday, June 20, 2011 5:34:54 PM(UTC)
sidfink43
Take off the belt and see if the motor is turning when it is supposed to be spinning. If so, the problem may be in the transmission/brake package which would then need to be replaced.
applianceman
#5 Posted : Tuesday, June 21, 2011 5:37:17 AM(UTC)
applianceman
If you decide you need to change the transmission this page will help
GE Washer Disassembly Guide
GE Washer no spin or agitate (Washer Repair)
by suniack 12/18/2017 7:09:50 PM(UTC)
GE washer no spin cycle (Washer Repair)
by fsuglover 4/8/2012 4:41:33 PM(UTC)
GE Washer No Spin For Larger Loads (Washer Repair)
by ACEMANNW 4/10/2011 10:42:31 AM(UTC)
GE Washer no spin/no water (Washer Repair)
by messtruck 2/19/2010 5:24:46 PM(UTC)
ge washer no spin or agitation (Washer Repair)
by floorman 1/11/2010 11:49:22 AM(UTC)
GE washer no spin when loaded (Washer Repair)
by spsnexpert 2/8/2009 5:13:05 PM(UTC)
