johnwashnock
#1 Posted : Wednesday, February 25, 2009 9:11:39 AM(UTC)
johnwashnock
I have a kitchenaid superba dishwasher. As far as I can tell for the lower washing arm--there are 4 parts The arm itself the bottom and top plastice bearing and the screw knob. My question is when screwing the knob down --it does not go flush with the top bearing. Should there be play(wobble)in the arm?
Drags1998
#2 Posted : Wednesday, February 25, 2009 2:08:35 PM(UTC)
Drags1998
The PLAY is NORMAL!!!!!! Water pressure when washing forces the arm up tight against the seal washer!!:)
nedunla
#3 Posted : Friday, January 11, 2013 11:07:30 AM(UTC)
nedunla
I have a Kitchenaid dishwasher (KUDS25SHAL1) and need to replace the lower wash arm upper bearing ring.... I got the part but it's all hard plastic and when I install it, the wash arm won't turn.... the old part is hard plastic on the inner ring, but is flexible/thinner plastic on the outer ring.... I have been told that I did get the right part, but how do I install the part so that the wash arm can turn?
Kitchenaid KSRG25FKSS15 Refridg buzz/rattle on compressor start (Refrigerator & Freezer Repair)
by Guest 6/23/2024 8:35:15 AM(UTC)
Kitchenaid refrigerator and freezer intermittently to warm (Refrigerator & Freezer Repair)
by Guest 6/18/2024 12:12:20 PM(UTC)
Kitchenaid KDTE254ESS1 Heater Element (Dishwasher Repair)
by charlie9876 5/28/2024 8:18:41 AM(UTC)
KitchenAid KSC25INSS01 (Refrigerator & Freezer Repair)
by KKellyNC 5/23/2024 4:25:25 AM(UTC)
Kitchenaid Oven range Superba kgsc308lss0 not heating up (Oven Repair (including Ranges and Cooktops))
by rattty 5/19/2024 6:51:16 PM(UTC)
Kitchenaid KDTM604KPS0 (Dishwasher Repair)
by Guest 5/12/2024 5:24:44 AM(UTC)
KitchenAid freezer gasket needed (Refrigerator & Freezer Repair)
by Kris Ballew 4/30/2024 6:27:57 PM(UTC)
KitchenAid freezer door stuck (Refrigerator & Freezer Repair)
by willeaton 4/18/2024 7:31:34 AM(UTC)
KitchenAid KSC25INSS01 issues (Refrigerator & Freezer Repair)
by KKellyNC 4/16/2024 7:28:06 PM(UTC)
Kitchenaid KSSC48QMS02 (Refrigerator & Freezer Repair)
by VinRenzi 4/2/2024 6:26:11 AM(UTC)
Kitchenaid Refrigerator Ice chute frosting up and clogging (Refrigerator & Freezer Repair)
by Guest 3/26/2024 9:05:12 AM(UTC)
Built-In Kitchenaid Mdel KSSC42QMS00 Refrigerator (Refrigerator & Freezer Repair)
by Guest 3/25/2024 6:29:18 AM(UTC)
KitchenAid KSSP42QTS00 Ice dispenser leaking (Refrigerator & Freezer Repair)
by sternern 3/20/2024 2:21:47 PM(UTC)
Kitchenaid ktdm354dss3 doesn’t close completely at the top (Dishwasher Repair)
by Guest 2/29/2024 12:36:40 PM(UTC)
KitchenAid Gar Range - Oven Intermittent Lighting (Oven Repair (including Ranges and Cooktops))
by JDinKTX 2/25/2024 5:05:21 AM(UTC)
