I had a technician come out and look at oven the oven is off by 50 degrees I replaced the sensor prior to technician coming out.The technician says it is the bord what do I need to replace and part number Thank You
The clock ( AP4103857) is the brains on this model. If your current board is misreading the sensor or not cycling the elements properly, then that is what you need.
