wrightralph
#1 Posted : Saturday, November 10, 2007 7:33:21 AM(UTC)
wrightralph
What is the easiest way to remove the 2 screws which attach the ignitor
Admin / APP Team
#2 Posted : Saturday, November 10, 2007 10:17:23 AM(UTC)
Admin / APP Team
Rank: Administration
Normally with a Phillips screwdriver. Sometimes due to excessive heat those screws are "welded" to the metal bracket. If force alone isn't enough, you can try a product called Rust Buster or you can simply drill the screws out with a power screwdriver or a small drill.
Rust Buster
UserPostedImage
XL44 Igniter Replacement Help (Oven Repair (including Ranges and Cooktops))
by atczumbar 11/30/2012 12:53:15 PM(UTC)
Gas Igniter replacement? (Oven Repair (including Ranges and Cooktops))
by BReader 4/11/2011 2:27:51 PM(UTC)
igniter replacement problem (Oven Repair (including Ranges and Cooktops))
by crush28 12/21/2010 9:58:44 AM(UTC)
igniter replacement (Oven Repair (including Ranges and Cooktops))
by Joost Schiereck 11/30/2010 12:11:36 PM(UTC)
Cooktop Igniter Replacement (Dishwasher Repair)
by andyaluu 11/27/2010 9:30:27 PM(UTC)
Amana Gas Broiler Igniter Replacement (Oven Repair (including Ranges and Cooktops))
by riverjamie 11/19/2010 6:16:24 AM(UTC)
Help-Need help with the igniter replacement (Oven Repair (including Ranges and Cooktops))
by mixer788 7/18/2010 4:19:26 PM(UTC)
Jenn-Air Cooktop Igniter Replacement (Oven Repair (including Ranges and Cooktops))
by bmmiller139 12/23/2009 8:32:33 AM(UTC)
GE Gas oven igniter replacement (Oven Repair (including Ranges and Cooktops))
by jessecoleman 9/21/2009 5:41:50 AM(UTC)
roper drop in gas range igniter replacement (Oven Repair (including Ranges and Cooktops))
by btthedge 6/10/2009 11:36:08 AM(UTC)
Thermador Professional igniter replacement (Oven Repair (including Ranges and Cooktops))
by jhendr1020 3/18/2009 12:26:12 PM(UTC)
WhirlPool Igniter replacement (Oven Repair (including Ranges and Cooktops))
by Matt.M 2/3/2009 12:50:53 PM(UTC)
GE spark igniter replacement (Oven Repair (including Ranges and Cooktops))
by keelo 6/30/2008 12:52:05 PM(UTC)
Thermador igniter replacement (Oven Repair (including Ranges and Cooktops))
by FrankEnstein 5/11/2008 7:17:17 PM(UTC)
Help! Range Igniter Replacement (Oven Repair (including Ranges and Cooktops))
by LSchm 4/4/2008 12:09:49 PM(UTC)
