I have an Amana ACS335OAS slide in range. The broiler Igniter does not turn on but the bake Igniter does. So I purchased the broiler igniter replacement. My question on this model does the range have to be pulled out in order to gain access to the wiring for the Broiler Igniter? I took down the Igniter but the wiring will not pull out to gain acess to the speed nuts?
