riverjamie
#1 Posted : 14 years ago
riverjamie
I have an Amana ACS335OAS slide in range. The broiler Igniter does not turn on but the bake Igniter does. So I purchased the broiler igniter replacement. My question on this model does the range have to be pulled out in order to gain access to the wiring for the Broiler Igniter? I took down the Igniter but the wiring will not pull out to gain acess to the speed nuts?
#2 Posted : 14 years ago
If you can not do it from inside the oven then the only solution is to pull the range out of the wall and remove the rear cover.
Here are the breakdown diagrams and Replacement parts for AMANA ACS3350AS Range - S/c S/i Gas | AppliancePartsPros.com
