when i turn the dishwasher on its starts to pump water in ready to wash but then after 30 secs or so it pumps the water back out and continues to do this, fill then empty, fill then empty. we have checked for any blockages and everything seems to be clear. anyone any ideas what the problem might be.
most bosch have a two year warranty on parts but not labor and a five year warranty on the control board I would check and see if the spray motor is getting voltage from the control board if not it is the control if it is it is the motor
Pull off the front panel. put you fingers i the unit and see if the bottom of the dishwasher is wet.
