mollyt
#1 Posted : Sunday, February 22, 2009 3:19:27 PM(UTC)
mollyt
My GE Profile Arctica Refrigerator is not dispensing ice or water. We changed the filter and got about two gallons out if we pressed the lever several times. Now there are no lights on the front panel and nothing is working on it. The refrigerator and freezer sections seem fine. We pulled the unit out and there isn't much dust behind it, no buildup on the vent on the back. Any suggestions, the mother board was replaced 2 years ago.:confused:
#2 Posted : Monday, February 23, 2009 1:07:42 PM(UTC)
Does it make any noise when you try to get an ice? Does the ice gate in the door open?
mollyt
#3 Posted : Tuesday, February 24, 2009 6:27:09 PM(UTC)
mollyt
Gene,
There are no lights on the panel, it doesn't do anything when you push in the bar to get ice or water. There isn't anything stuck in the chute.
Mollyt
#4 Posted : Tuesday, February 24, 2009 6:58:35 PM(UTC)
Mollyt,
Open the ice & water dispenser, using the instructions from one of our previous posts: http://forum.appliancepartspros.../9931-ice-trap-door.html and check the switch (#72 on the diagram).
If there is nothing wrong then the problem most likely is a bad main control board on the back of the refrigerator.
Here are the break down diagrams and the parts list for the GE refrigerator Model PSI23SGMDFBS
Water/Ice Dispenser not working (Refrigerator & Freezer Repair)
by Azurescens 2/5/2013 4:21:41 PM(UTC)
Water/Ice dispenser not working... (Refrigerator & Freezer Repair)
by CartmanMTB 1/31/2011 2:05:25 PM(UTC)
Water/Ice Dispenser not working after the refrigerator stopped. (Refrigerator & Freezer Repair)
by kanhs 6/1/2010 9:19:35 AM(UTC)
GE mainboard replaced, now water/ice dispenser not working. (Refrigerator & Freezer Repair)
by TravisR 4/2/2010 9:27:59 PM(UTC)
