2 Pages<12
ForDaFingaz
#11 Posted : Sunday, November 25, 2012 8:00:52 AM(UTC)
ForDaFingaz
The extra wire you are talking about is probably the green (ground) wire which should be removed by the installation instruction (page 2).
Gene [or anyone] - The color of the extra wire in the photos provided show the wire as being black [not green]. This is how it appears in my oven as well. Is this really a ground wire that can be removed? You can see it in the photo that has the caption "This is the extra pin I mentioned in Q1". I just want to verify this before I complete my repair.
Thanks in advance for any help.
#12 Posted : Monday, November 26, 2012 12:32:29 PM(UTC)
All wires are colored according the code. Black wire is always hot and should not be removed.
In order to provide most accurate advice we need the complete model number of the oven.
ForDaFingaz
#13 Posted : Tuesday, November 27, 2012 10:32:31 AM(UTC)
ForDaFingaz
Found my answer on another forum. I was confused about the COM0 and COM1 on the new board. Looks like things are functioning now, although not sure about the fans or how I can test to see if the fans are working as expected. Any help here?
#14 Posted : Tuesday, November 27, 2012 1:43:18 PM(UTC)
You forgot to post the complete model number of the oven.
2 Pages<12
