This unit does not defrost, it does not have an ice maker, I have not found a schematic either. a temp sensor clipped to the evaporator coil looks like it may be swollen, problem?
YES!!!! Its the defrost thermostat, replace it and defrost the coil and you will be all set!!!!
Can probably find you a wiring diagram but your model number should have another 5 or 6 alphanumerics at the end. |
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman  Can probably find you a wiring diagram but your model number should have another 5 or 6 alphanumerics at the end. Model TT14DKXKQ02 It had a paper tag on the freezer door with the partial model I missed the complete model tag inside the refrigerator compartment. Thanks in advance
THANK YOU! you guys are great, quick response and accurate, thank you!
