Washer123
#1 Posted : Saturday, February 21, 2009 3:30:50 PM(UTC)
Washer123
This unit does not defrost, it does not have an ice maker, I have not found a schematic either.
a temp sensor clipped to the evaporator coil looks like it may be swollen, problem?
Drags1998
#2 Posted : Saturday, February 21, 2009 4:32:53 PM(UTC)
Drags1998
YES!!!! Its the defrost thermostat, replace it and defrost the coil and you will be all set!!!!
#3 Posted : Saturday, February 21, 2009 5:13:35 PM(UTC)
Can probably find you a wiring diagram but your model number should have another 5 or 6 alphanumerics at the end.
Washer123
#4 Posted : Saturday, February 21, 2009 6:35:18 PM(UTC)
Washer123
Model TT14DKXKQ02 It had a paper tag on the freezer door with the partial model I missed the complete model tag inside the refrigerator compartment.
Thanks in advance
#5 Posted : Sunday, February 22, 2009 3:05:46 AM(UTC)
Washer123
#6 Posted : Sunday, February 22, 2009 5:10:52 AM(UTC)
Washer123
THANK YOU! you guys are great, quick response and accurate, thank you!
