my dishwasher no longer cleans properly. over the last month or so i have noticed standing water at the bottom of the tub after the cycle. please advise on what i should be looking for .
Here are your parts Model DW961UQWhere is a service manual. Although not the exact Model Number, it should be close to yours. Also not the best quality but is the best I could find. http://www.servicematters.com/m...ibrary/docs/16007822.pdfDrain problems are often a partial plug of the drain hose. Especially where it goes over the fitting into the plumbing. The poor wash/drain you also indicated could be just a dirty filter. Also perhaps a problem with the flapper valve Open it up and take a look. |
THIS FORUM IS DEAD!!!!!!! |
