My Frigidaire (says Electrolux by the model #) dryer has a burner problem. Sometimes the burner will light, more often it won't. I can hear the igniter clicking on with no results. I have checked gas line, no problem there. Have cleaned dryer of all lint, including screens, etc. Found 1 fuse, it appears to be fine. Anybody have any ideas?:confused:
Originally Posted by: billshaf  My Frigidaire (says Electrolux by the model #) dryer has a burner problem. Sometimes the burner will light, more often it won't. I can hear the igniter clicking on with no results. I have checked gas line, no problem there. Have cleaned dryer of all lint, including screens, etc. Found 1 fuse, it appears to be fine. Anybody have any ideas?:confused: Billshaf, You most likely have a gas valve coil problem. Part number: AP2150379
Since the problem is intermittent, and you've cleaned everything out,including the exhaust vent pipe ? It's the most likely problem, with your description. :) :) :)
Thanks --I'll try to order parts.
Originally Posted by: billshaf  Thanks --I'll try to order parts. Billshaf, OK, I'm pretty sure that will get you where you need to be. If you need more information, drop us a line. :) :) :)
