I am getting water to the dispenser but no water to the ice maker. Are there 2 fill valves for this unit? Also I am going to replace the water filter because is is due to be changed. On the schematic for this unit I only see one water line going to the ice maker, I do not see one going to the dispenser.
the tube at the back of the frige going to your ice maker mybe iced up, pull it out and rinse it out replace it back good luck
