The washer will fill with water and drain - it just will not spin or agitate - it won't even spill when set on the Spin Only cycle.
Don't know where to start - turned power off and let sit and then back on - :mad: any help would be appreciated
Remove the front panel and check the lid switch (#388 on the diagram). Here are the break down diagrams and the parts list for the GE washer Model WASE5210B1WWGene.
