jacki
#1 Posted : Sunday, February 15, 2009 12:49:26 PM(UTC)
jacki
Hello,
I put my clothes in the dryer about 5:00 pm and went back the next day and the dryer was still running wiht no heat
Can anyone help?
Thanks so much!!
Jacki
#2 Posted : Sunday, February 15, 2009 12:54:35 PM(UTC)
A Model Number might help
I assume it did not turn off because the timer did not advance.
Is this correct?
Try it in a timed dry mode
Does it advance now?
If the heater burned out most units will not advance in auto mode
Also could be a thermal fuse blew
Also could be you lost half your line voltage
Turn the breaker off/on a couple times slowly
Better yet check the voltage at the plug
jacki
#3 Posted : Monday, February 16, 2009 8:17:08 AM(UTC)
jacki
Hi there!
Sorry the model # is RGL 463 4BL0
You are right -it did not shut off because the timer did not advance.
Checked all timed modes and it will not advance
also checked breaker and plug...everything looks ok there
Do you think it is the timer?
Thanks for your help
Jacki
#4 Posted : Monday, February 16, 2009 9:06:14 AM(UTC)
Model RGL4634BL0
Here is the wiring diagram
https://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%203398163.pdf
Yes it does sound like the timer is shot
In timed dry the circuit path for the timer motor is
NEUTRAL , DOOR SWITCH , WB/TM timer contacts , TIMER MOTOR , L1
So even with the unit off as long as the door switch is closed the timer should advance to the OFF position.
Am concerned that you had no heat.
Try running the unit to check this.
You may have two problems
