I have a Cabrio by Whirlpool washing machine. I keep getting a F1 code on the display panel. It stops in the middle of the cycle displays the code and beeps.
Any idea of what the problem is?
Please post a model number so we can see exactly what you have. In general on the Cabrio that error code indicates a primary board failure. Also, there should be a tech sheet inside the machine under the top. (Primary Control Failure)
F then 1 flashes when there is a primary control failure. Replace the machine control assembly.
DISPLAY
(Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
